Documentation for Users  2.1.2
Perception Toolbox for Virtual Reality (PTVR) Manual
Visual angle of objects
Note: This section is under construction but the following links or demos are operational.
Links
Demos
Python file
Description
Main demos in : ...\PTVR_Researchers\Demos\Objects\
angular_size_of_object.py
How to specify the angular size of an object.
angular_size_check.py
How to check if the angular size of an object is correct.
